My paceheaders came in but now having problems
Hello everbody my paceheaders came in the other day and they are very nice. But now I am having a big problem after installation. It sounds very nice and loud through my Corsa exhaust and my cutout on my i-pipe which I have it running through my cutout. I got it installed and tuned at Revxetreme which they did a good job. But my problem is that when I was going to my dads house to drop my brother off. In his street he has speed bumps and when I was passing over them at a angle very slow I heard like grinding. I was like what the F@!@ when I got to his house I looked under my car and the clamps were like almost touching the ground. So I rejusted 2 clamps moved them a little bit up away from the ground some what. And now just driving I hear grinding I think I moved the driver side clamp to much which is agaisnt my car now. Im like freaking out man! don't no what 2 do. Also I think I should have my y-pipe souldred togheter so it sits a little higher some what. I am also on sportline springs I no very low. Please somebody help me. Sorry for all the writing but I need help from my f-body friends. Thanks
i had the same problem i just got 3 in band clamps and used them or you can have it welded but u are setting very low for an aftermarket y pipe u will prob drag just a hair every now and again no matter what you do
So does that mean every time I go over speed bumps I will drag even if I am welded. There is no way I could have the TSP offroad y-pipe moved a little. Does anybody with sportlines in here have that problem also. Thanks for your help.
So does that mean everytime I go over a speedbump I will rub and grind even if I am welded. What about if I have the TSP offroad y-pipe moved a little bit. If anybody in here has sportlines also and has this problem fixed please let me me no what you did or what to do. Thanks
you can try to readjust the y pipe and put band clamps on there to help with the dragging problem, however, with readjusting the y pipe, you have to take floorboard banging into consideration - make sure you leave enuff clearance there
