Ported TB and MAF!!! Now have problems...
Old 06-12-2006, 03:14 AM
DarkHawkLS1's Avatar
Default Ported TB and MAF!!! Now have problems...
Well, the MAF was semi ported before, but I had a buddy polish it up some more as well as porting the TB.
When I drive the car around now and get on it...it won't downshift, and the converter just locks letting the car casually rise in RPM's. With the research tonight, I can assume with my A4 that I either ported the MAF too much, or something else is wrong with the car. I should have just let the MAF alone. It was already descrened and everything before. Never had any problems! My car idle's now at 1300 rpms
Maybe I need to set my idle screw down a bit, or just get it retuned.
Anyone??
Old 06-12-2006, 04:15 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Try a straight up stock MAF on there before you do anything. That might be the actual problem. You might have been "lucky" before.
Old 06-12-2006, 06:59 AM
Mike02Z's Avatar
Isin't there a kickdown cable attached to the TB on an A4? Did you forget to put that back on? Just an idea.
Old 06-12-2006, 09:05 AM
That's what she said...
TheBlurLS1's Avatar
Kickdown cables went the way of the Dodo with TPS's and computer controlled transmissions.
Sounds like your friend might have hogged it out a little too close to where the blade makes its seal at. Are you positive that you hooked everything up right? Did you make sure that the IAC has its O-ring still in place?
Old 06-12-2006, 11:51 AM
I'm positive I hooked everything up right. We never took the shaft out, so the O-ring is still in there.
Old 06-12-2006, 03:07 PM
oxidizr's Avatar
Too much porting ...
Old 06-12-2006, 03:33 PM
LS1ownzYOU's Avatar
isnt the stock MAF good to like 400rwhp, whyd you port it at all..?
Old 06-12-2006, 04:10 PM
TheBlurLS1's Avatar
More like 500+rwhp. People port them because they think bigger is better.
Old 06-14-2006, 06:17 PM
The car runs strong now, nothing was wrong. I just disconnected the battery, waited 10 mins, reconnected it. Ran the car 10 miles, and then let it sit over night. The next day I went out and it pulls harder than ever.
Old 06-15-2006, 02:16 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Ahh, the battery disconnect mod....very worthy.
It probably just found idle after you did that.
Old 06-15-2006, 10:57 AM
Z'mnypit's Avatar
Made 620+ with the stock MAF on my car. Its decreened but thats it. Not one problem with it.
Old 06-15-2006, 02:06 PM
nevermind guys........I found out today that my tranny is going out. I think I'm going to sell the car, it's giving me too many problems and gas expenses are crazy for this daily driver.
