DENSO IRIDIUM PLUGS
DENSO IRIDIUM PLUGS
DOES ANYONE KNOW HOW MUCH THESE PLUGS ARE?
FOR 2000 Z28 M6.
THANKS FOR THE INFO. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
FOR 2000 Z28 M6.
Re: DENSO IRIDIUM PLUGS
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by SILVER:
<strong> DOES ANYONE KNOW HOW MUCH THESE PLUGS ARE?
FOR 2000 Z28 M6.
THANKS FOR THE INFO. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I believe NGK iridium, which use the same idea, are $6/piece => $48 /set at Thunder racing.
FOR 2000 Z28 M6.
Are the NGK Iridium plugs that much better than Platinum? Are the worth the $$. Will you really notice any difference? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Denso's iridiums are the best spark plugs you can buy. There about $10 a peice, but are excellent, you can run them with Nitrous or Superchargers/Turbos.
Supposedly they give the conductivity/power of a copper plug while lasting as long as a platinum plug. A Mustang mag did a test on them and did gain some HP, quite a bit actually. The test was a best case scenario for the plugs though- a blown motor with lots of cylinder pressure.
I'm a bit leary of power gains on a stock LS1 over copper plugs though. I used to road race production bikes. I the production classes you can't do alot of stuff to the motor. I tried almost every widget know to man within the rules. Split Fires, platinum plugs, timing advancers, advancing and retarding the cams, drop-in K&N filters, heck I even tried Slick 50. Every change was tested on a dyno, the only widget that worked was-20W Redline oil. Picked up 2-3 HP over 10W40 Motul. That's it. Widgets suck!
If I see some tests were they actually give power in a normal scenerio-then and only then will I pay 10 bucks a plug. One dollar copper plugs work just fine for me, just have to change them more often. Perpetually Cautious, but willing to change my mind!
Originally Posted by DrkPhx
Average price is $96 for the set. One of Predator distributors has them for $78/set shipped.
Originally Posted by damon_Z
Do you know which of the Predator distributors had them for $78 shipped? Is the distributor a sponsor? Thanks in advance for the info.
