How do you guys rate these headers
http://www.gravanatuning.com/applica...IGNITION_WIRES
I`m thinking on these, cause I haven`t much room for anything else.
Input appreciated
Thanks
Pete
Input appreciated
Thanks
Pete
lol not a GTO mate, a Vauxhall Astra Coupe ................
Have look here .... https://ls1tech.com/forums/conversions-swaps/460867-ls1-into-vauxhall-astra-coupe.html
This is the room I have, note the flange of the standard cast header, ok, the body work has to be trimmed to tidy, but, there`s not much room for anything but shorties.
Originally Posted by Pete 1
Which ones would you go for then ?
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
any shorties will be better than stockers...never heard of those...would get a name brand though--never now how these other companies will compare unless you can see them...try Edelbrock maybe.
Ouch... Yeah not much room there. Shorties will probably only get you a good apearance gain. Those are expensive as well... If cost is not a problem I would take the shorties and concentrate on the rest of the build, otherwise your stock manifolds will flow around the the same. Probably looking at most a 5-10 hp difference over the two.
Pacesetter makes shorty headers at a reasonable price. You can even get them coated and they should be under $380.00.
Originally Posted by Formy
Pacesetter makes shorty headers at a reasonable price. You can even get them coated and they should be under $300.00.
like said the pacesetters are resonably priced and i'm sure they flow enough to hang with them to.... i dunno about coated for $300 though i got some for a little under $430
Pete 1: pm me if interested - non sponsor
Originally Posted by RrCoX22
they JBA's are well known but they are bank.....
ЯєŧąяĐ Єl¡m¡иąŧøя ™
gravanatuning.com/applications/2004_Pontiac_GTO_5.7.aspx/19/3418/_JBA_STAINLESS_STEEL_GTO_HEADERS_WITH_IGNITION_WIR ES
Input appreciated
Thanks
Pete
Input appreciated
Thanks
Pete
Here is an overview on how hyperlinks work.
http://www.learnthenet.com/English/web/080www.htm
For some reason, it lost the [url] ...
