Hooker or SLP?????
Hooker or SLP?????
am planning 2 buy a headers but wich one is better the hoocker or the slp?
am goona keeb the stock y pipe.
cuz i insalld an eibach Sport-Line Springs.
thanx.
<small>[ March 27, 2003, 12:51 PM: Message edited by: Pro Stock John ]</small>
thanx.
Re: Hooker or SLP?????
You can't keep the stock ypipe with any LT header. For the best header check out QTP--->
Hookers are a nice alternative for a pretty good price too. The SLPs aren't cheap nor are they the best.
Just an opinion.
Just an opinion.
Might want to do a search on the fitment issues with the SLP headers, as well as clearance issues. Seems to me people tend to prefer the Hookers for price/quality purposes. Might want to check into that new sponsor Kooks too.
Buy the hooker headers! I have mine on the shelf and will be installing them soon. They were cheap and I heard they sound good too! I can't wait to get them installed!! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
If price is not an issue, many ppl that can afford it are going with FLP's. Take a look, their headers are sexy looking! <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
I think the Hooker LT is cheaper LT's, i have hooker LT on my car before i install it my car was run at 1/4 110 MPH after install it i run at 1/4 114 MPH, i won from the hooker LT at 1/4 4 MPH, this result without any tuning on PCM.
Note: Headers LT's on stock internal need a tuning (LS1edit) to worth better flow.
God saves USARMY <img border="0" alt="[USA]" title="" src="graemlins/patriot.gif" />
If your car is lowered, or you plan on lowering it in the future, definately get the Hookers! Awesome fitment and clearence. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
If you are not going to be lowered... Get the Hookers anyway! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> Just look at those spaghetti (sp?) bends on the SLPs! <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
ClassicCollector, Did you get the cutout cap ok?
ORY, or Off-Road Y-pipe has no cats. The Hooker ORY is not a bad y-pipe. I ws running it before the true duals and it performed just fine. My car is lowered with Eibach Pro-kit springs and the clearence issue was not that bad. You just have to be a little more aware of where you're driving, and take speed bumps slowly.
ohhhhhhhhh good good thanx alot .
so i cane istall a y pipe. <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" /> <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Here is what the underside looks like on my car with the Hooker headers and ORY pipe. You may have clearence issues if you try to weld up the stock cats to these, since they will be under the car and not tucked up next to the engine like with the stock manifolds.
<img src="http://www.fototime.com/A1FFC469F2747FB/standard.jpg" alt=" - " />
ohhhhhh com on what shold i dooooooo
H E L P . <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> .
cant i install a hoocker fry pipe???
IF you don't have emission testing in your state, just order the Hooker LTs and the Hooker ORY. Put the headers then drive it to an exhaust shop and have them weld up the ORY pipe for you and be done with it (unless you can weld yourself, in which case it will be even easier). If you do have emission testing, you will need a set of high flow cats (or the stockers), and have the stuff custom done for you.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by jaywoo:
<strong> IF you don't have emission testing in your state, just order the Hooker LTs and the Hooker ORY. Put the headers then drive it to an exhaust shop and have them weld up the ORY pipe for you and be done with it (unless you can weld yourself, in which case it will be even easier). If you do have emission testing, you will need a set of high flow cats (or the stockers), and have the stuff custom done for you. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You don't need to have the Hooker ORY welded! Its got slip fit connections.
I'd recommend Random Technology Cats if you want high-flow cats. They're like 120 bucks through a few of the sponsers.
Lots of people complain about some rasp issues w/ a ORY, but i think that was mainly w/ a bullet muffler or Loud Mouth exhaust.
My vote is for the hookers tho, just make sure ya do a good Y pipe. Mufflex might be able to help...www.mufflex-performance.com
thanx all.
and MOBE my car is lowered.
so guys the hoocker is the best chuis with the stock y pipe .
not the FLP or QTP or SLP.
BUT ON SLP SITE THEY SEEING 40HP+????
IS THAT TRUE??????
IS THAT TRUE??????
The only way you will be able to use the stock Y-pipe with the Hooker LTs is to have a shop custom fab you something. They won't bolt right up. Are you planning on running high flow cats or no cats? If you are going the no-cats route, you may want to consider the Hooker ORY pipe.
