Backfiring after cam & header install???
Old 03-27-2003, 11:24 PM
BAD XXX's Avatar
Default Backfiring after cam & header install???
I recently had a cam & headers installed, with LS1 Edit tuning. 200 miles later, I am getting a lot of backfiring. At WOT, the exhaust backfires repeatedly above 4000 rpm and the engine surges. Even at idle, I will get an occasional loud pop at the tailpipes. Do I need additional tuning or is something else wrong?
Old 03-27-2003, 11:31 PM
Venkman's Avatar
Default Re: Backfiring after cam & header install???
I would call/go to whoever tuned it
Old 03-28-2003, 11:17 AM
Kevin 276's Avatar
We need tuning details...what is your autotap showing???
Old 03-28-2003, 02:22 PM
gwj
gwj's Avatar
Location: Live Oak, FL - in the woods where the creatures lurk.
Wow, that could cover a lot of territory. Did you upgrade springs w/the cam install? etc,etc. First thing I would do is pull the plugs and have a good look at them.
Old 03-28-2003, 02:39 PM
LS1TECH Sponsor
Magnus's Avatar
I also suggest checking valve springs.
Old 03-29-2003, 12:52 AM
ssdungeon's Avatar
Sounds like my car. I found 4 pinholes in my exhaust welds that were not noticable when first welded. After a few hundred miles we had the car back on the lift to add bling bling chrome tips and noticed the burnout pinholes. When we welded them. My exhaust was deeper and the backfires went away. Every now and then when coming from full throttle there is a little pop, but not bit POW! like before and I think its from my cutout seal leaking it was in pretty bad shape so I purchased a mettle gasket to replace the paper one.
I dont know if this will help you but good luck.
