3 , 3.5 , 4 in piping
Old 06-16-2006, 08:54 PM
SLP4CamaroSS's Avatar
Default 3 , 3.5 , 4 in piping
making a custome ypipe and exhaust what inch piping should i go?
Old 06-16-2006, 09:10 PM
HeapaShifter's Avatar
3 inch unless you're making big horsepower.
Old 06-16-2006, 09:42 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Anything bigger and you will almost be losing power due to the negatives such as less scavenging.
Old 06-16-2006, 09:57 PM
cuz they said a 3inch y pipe flows as well as a 2.5 x pipe so a 3.5in y pipe and exhuast would be ok and flow as well as a 3in xpipie
Old 06-16-2006, 09:59 PM
or even a 3.5 or 4 y pipe and reduce to a 3inch
Old 06-16-2006, 10:20 PM
Ferocity02's Avatar
3" Y-pipe is more than enough for stock cubes.
Old 06-17-2006, 05:11 AM
found this in the sticky
A 2.75” (stock) single system is good for a 310hp engine with zero loss…
A 3” Single system is good for a 370hp engine with zero loss…
A 3.5” Single system is good for a 503hp engine with zero loss…
A 4” Single system is good for a 657hp engine with zero loss…
A 2.25” dual system is good for a 457hp engine with zero loss…
A 2.5” dual system is good for a 513hp engine with zero loss…
A 3” dual system is good for a 812hp engine with zero loss…
Old 06-17-2006, 07:13 AM
Viper's Avatar
2.5" y-pipe to a 3.5" i-pipe and catback here. Plenty of flow.
Old 06-17-2006, 07:52 AM
02RedHawk's Avatar
2.5" Y-pipe to a stock 3" i-pipe/catback, plenty of flow here, too. (see sig)
Old 06-17-2006, 12:19 PM
Ferocity02's Avatar
But with what design pipe, how long, how many bends, etc... A 3" pipe would support 1000hp if it was straight and only 6" long.
