FAST TB 78mm bearing removal
Old 06-17-2006, 06:16 PM
wanklin's Avatar
Default FAST TB 78mm bearing removal
I have disassembled the TB to a point where all that is left is the bearings. I tried to hook them out but they won't budge. Unless I can get the bearings out and replaced my powedercoating dreams are not going to come true...
any suggestions?
Old 06-18-2006, 03:13 PM
wanklin's Avatar
not looking too promising ;o/
Old 06-18-2006, 03:49 PM
That's what she said...
TheBlurLS1's Avatar
I don't know what to tell you man! You might try putting it in the oven on about *250, then trying to remove it. I'm not sure how they are installed, but probably with a press. You could send a PM to Nick Williams and ask some questions, or refer to this thread. He might be able to shed some light on the subject.
Old 06-19-2006, 08:13 AM
Nick Williams's Avatar
I would just put it in the oven to heat it as mentioned. Then you should be able to get them out. They may even fall out.
Nick
Old 06-19-2006, 08:23 AM
Weezzer's Avatar
Nick
Yea, that will work. As the TB gets hot the components will grow in size and get larger because of the heat, but since the bearings are made of unobtanium they aren't affected by this heat and won't become any larger and will fall out.
Old 06-19-2006, 04:40 PM
wanklin's Avatar
I will give it a try ;o)
Thank you very much.
Old 08-01-2006, 10:38 AM
wanklin's Avatar
This method did not work for me.
