#8 Spark Plug = WOW
Old 06-17-2006, 07:27 PM
Sunset'01Z's Avatar
Default #8 Spark Plug = WOW
Ok so yesterday i changed out my spark plugs.. well 7 out of 8. the first 7 were easy and took me less than 3 hours. the last #8 plug was a royal B*TcH! I went at it from under the car, like i was told, got the socket on it, but couldnt get the wrench on the socket to turn it! i used a wobble attachment and even tried all kinds of extensions to get the wrench out from the engine bay lol but nothing worked! how are you guys changing it? help me please!
Old 06-17-2006, 07:28 PM
brad8266's Avatar
Try using the spark plug socket with vice grips on the end instead of the socket to break the plug loose and then take it out by hand.
Old 06-17-2006, 07:40 PM
Sunset'01Z's Avatar
what about tightening it back up?
Old 06-17-2006, 07:44 PM
Trunion King
bene's Avatar
If took off the coil rack, it should be easy taking the #8 plug off from the top. I used a torque wrench w/ an extention, adapter to the plug socket.
Old 06-17-2006, 08:00 PM
JMBLOWNWS6's Avatar
This is why I love a car with headers
Old 06-17-2006, 08:18 PM
Luna's Avatar
a 1" extension is perfect for #8 unfortunately most people don't have a 1" extension
Old 06-17-2006, 08:47 PM
SSU, come over and relax
skywalkrNCSU's Avatar
yeah headers definatly makes it easier....my buddy was helping me when i did new plugs and wires and he got #8 from the bottom pretty easily
Old 06-17-2006, 09:22 PM
INMY01TA's Avatar
Not too hard. (with headers anyway) I got long skinny arms tho.
Old 06-17-2006, 11:02 PM
_JB_'s Avatar
werd, it only took me 2 mins to get #8 out and a new plug in. Taking off the wire though was a bitch.
Old 06-17-2006, 11:42 PM
Arachnotron's Avatar
It wasn't too difficult from the top.
http://www.installuniversity.com/ins...g_and_wire.htm
Old 06-18-2006, 12:36 AM
iverson387's Avatar
ya getting the number 8 plug wire was deffinitely the hardest and most time consuming but with a 1 inch extension and a ratchet with a swivel head i got out the plug in 2 min. the whole plug and wire change took me less than an hour on a car without headers.
Old 06-18-2006, 12:48 AM
That's what she said...
TheBlurLS1's Avatar
You need one of the long wrenches pictured here. Some people take their sparplug wrenches and put a box/open end wrench over the hex part of the socket, helps with low clearance.
Old 06-18-2006, 08:56 AM
mrr23's Avatar
remove the coil pack and go from the top.
Old 06-18-2006, 09:15 AM
Mike02Z's Avatar
Pivoting flex head ratchet like pictured above. That made number 8 a snap from the top once the coil pack was off. It's all about the right tools. That flex head ratchet made most of the plugs very easy to pull. 25 bucks at Sears. I advise getting one.
Old 06-18-2006, 07:04 PM
Zymosis's Avatar
With the plug wires off, and long arms, I reached them from the top, going right under my strut tower brace next to the engine from the front of the car.
Old 06-18-2006, 07:14 PM
Ferocity02's Avatar
Spark plug socket with 1" extension and a 3/8" ratchet from the top = spark plug change in 10 minutes.
Old 06-18-2006, 08:28 PM
brad8266's Avatar
I have headers and I just use the spark plug socket and a rachet, takes about 1 minute to swap #8
Old 06-18-2006, 08:43 PM
Mr. Luos's Avatar
Once you have a method it will only take you 45 minutes to get all 8 swapped out.
I have big hands so I remove both the coilpack AND the valvecover on the passenger side. A 1 3/4" extension makes life easy.
Although the water temp. sender makes things a little tight on #8.
Old 06-18-2006, 08:59 PM
YEV33's Avatar
I have an M6 and it literally took me 5min. to get the #8 plug from the bottom. I used a standard spark plug socket and a regular wrench. An automatic might be a little different.
Old 06-18-2006, 09:38 PM
sdbrown84's Avatar
Removing the coil packs does help. You can do it with a pivot attachement as well. Put on a set of mechanics gloves and reach way down there. You should be fine.
