o2 sensors
o2 sensors
what exactly do o2 sensors do? and do all headers require them?? beacuse im thinking about putting longtubes on, and everytime i look one up on ebay or any other website it always has another link about o2 sensors.
SN95 Director
in short there part of the system that regulates your AFR. you need your B1S1 and B2S1 o2', you dont need the rear ones. most likely your reading about needing o2 sims which are needed to plug up the rear o2 sensors to fool the pcm into thinking that they are still present. your car will run with no rear sensors, it will not with no front sensors.
((((((Administrator))))))
...another thing about LT headers is that you might need o2 extensions.
Peace,
Craig.
thanks, but another stupid question is when i order longtubes will it have everything there for me to install it, or do i have to order more with it. Sorry about all these questions i dont really know alot about this topic.
Depends. I ordered the Dynatech Supermaxx headers from Thunder Racing for my 2000 TA partly because it was a complete kit with everything needed...Headers, Y-Pipe and O2 extensions. Talk with the sales people at some of the sponsors to the right, they are very knowledgable about these cars and will usually work out a package for you considering your goals and budget
Hardware wise, ask the vendor you're buying the headers from what they include or what you need.
Ok, LT headers. You'll need a y-pipe from the same brand headers you get. You should get all the hardware, but like I mentioned ask the vendor.
You might need o2 extensions.
Make sure you get the correct year headers for your car, the A.I.R. tubes vary from the years. 98-99 and 00-02 are the 2 types I believe, and of course the 01-02 does not have EGR.
O2 simms or have the rear o2's deleted.
Reuse the stock exhaust manifold gaskets.
While the headers are out you might want to go ahead and put some NGK TR55 plugs and some better wires while you can easily get in there when the headers are out.
Thats about it, you can try the search option and read up some more about this subject.
Peace,
Craig.
thanks craig for all the information man. i just want to make sure i get all the right things at one time and not look like an idiot when i go get installed and have everything for them.
Peace,
Craig.
haha again, what is that for just for curiosity.
Peace,
Craig.
personally, i'd buy new STOCK header gaskets... they are usually reusable, but they only cost 15 bucks, and its not worth the pain and hassle to do it all again, if one goes bad after the swap. just get new ones, the extra peace of mind is worth the money!
I agree, the multi layer metal header gaskets are all I use...you dont need any RTV sealer or anything, and you can reuse them and there isnt any scraping the junk off the flanges and head!
If you have problems with the 02 sensors not getting hot enough since they are further down the exhaust stream, you can pick up the Bosch 13111s (vette rear 02s). These have a hotter sensor element and also have a longer wire so you won't need the 02 extensions anymore either (sell them).
