prohane motor mounts not lining up???
im putting a set of prothane motors mounts and i got one side to line up...but the driver side is not even close to lining up...i tried taking the the part where the mount sits on.....which is the part that is bolted on the frame....i got it to line up but now it doesnt want to bolt down to the frame anymore....only two bolts want to line up.....its getting frustrated....ive been at it for a bout 2 hrs......!!!!any one had the same problem
That's what she said...
I bolted my mount to the pedestal, then bolted the pedestal to the K-member when I installed mine. Try taking the tranny mount bolt out of the crossmember and shoving the trans over a little, might help you get it started.
With enough prybar action, you should be able to tweak anything into place though.
