What size
What size
I am going to be running a td set up on my car and I know that space is limited. I was planning on getting Kooks LT 1 7/8" x 2" x 3 1/2" w/ Kooks X-Pipe that is 3 1/2". Is this going to fit or will it be too big. Also if it will fit how about ground clearance? Thanks for the info.
If you do 3.5" duals you better plan on staying at stock ride height. Like Blur said it'll take some work and tweaking to get the exhaust to tuck up there but I think you'd be OK on a stock height car. Why 3.5"? How much power you plan on running anyway? Seems a little overkill unless you're going for huge power levels.
