SSRA or FTRA gains over FRA?
Old 04-16-2003, 04:55 PM
BADSZ28's Avatar
Default SSRA or FTRA gains over FRA?
Anybody run at the track or the dyno with FRA and then with SSRA or FTRA? Any feedback would be appreciated.
Thanx.
Old 04-16-2003, 07:59 PM
ss1le02's Avatar
Default Re: SSRA or FTRA gains over FRA?
I'll be comparing FRA to SSRA this w/end if the weather's good. I'll also be trying the track version of the Supersucker, over the street version.
Old 04-17-2003, 11:49 AM
KYSpeedFreak's Avatar
Keep us informed on your track gains.. Id really like to know how much the track version holds over the regular version...
Old 04-17-2003, 05:24 PM
BADSZ28's Avatar
There are two different versions of the SSRA's? Where can I see these? What are the differences?
Thanks.
Old 04-17-2003, 07:41 PM
ss1le02's Avatar
Here's a pic of the track version of the lower box.
www.buickwe4.com/pic/DSC00012.jpg
It slides into the top just like the street version. This bottom box is big and ugly. It hangs about 3 inches lower than the regular version. Instead of a 2 inch mouth, this one is about 5 inches wide. This CANNOT be used on the street. If you did, you would wreck it in about 5 minutes. It's not pretty, but I'll see how it works hopefully this w/end if the weather cooperates.
Old 04-17-2003, 07:46 PM
Im anxiously awaiting your track results... Im possibly buying this and the track version to slip on long enough for a few local street races if there is much of a difference..
Be sure to keep us informed...
Old 04-17-2003, 08:00 PM
ss1le02's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 11secTA:
<strong> Im anxiously awaiting your track results... Im possibly buying this and the track version to slip on long enough for a few local street races if there is much of a difference..
Be sure to keep us informed... </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">It's forecasted to rain this Saturday. Hopefully it won't so I can run the car. If you're going to street race with the track version, I would only use it for the run. Then I would take it off or you'll bust it. I'll let you know how it performs. E-mail me for more info on the track version.
Old 04-19-2003, 12:54 AM
ss1le02's Avatar
It looks like the weather will be good. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> I'll post when I get back.
Old 04-19-2003, 06:43 PM
ss1le02's Avatar
Went to the strip. I only got 2 runs in before it started to rain. I was very inconsistent. I got a 13.6 and a 13.2. I think the track was very green and cold. This was there first event of the season. My previous best time was a 12.75 on the F1's with 4.10's. I've since installed long tube headers and a Comp cam 224/.581/112LSA. I was hoping for low 12's high 11's. I could not hook at all. I was spinning all the way through 2nd and most of third. I would let off then floor it again and it would still spin through 2nd and even 3rd. My previous best 60ft. time on the F1's was 1.967. Today my 60ft. times were 2.20's.
So as far as comparing FRA to the Supersucker to the track Supersucker, I can't give you any feedback.
Old 04-20-2003, 02:19 PM
00z
00z's Avatar
does the ssra go infront or behind the radiator? if it's in front wouldnt that create a cooling problem?
Old 04-20-2003, 09:15 PM
ss1le02's Avatar
All cold air/ram air kits mount in front of the radiator. On Autotap, my car consistently runs 180 degrees.
I need drag radials.
<small>[ April 20, 2003, 09:18 PM: Message edited by: ss1le02 ]</small>
Quick Reply: SSRA or FTRA gains over FRA?
