any other way to remove p/s pulley
There's an actual tool, about the size/shape of a socket with a threaded inside that a bolt goes through. You loosen the bolt almost all the way out of the threads and one side of the socket-shaped piece has something that looks like a c-clip that fits over the small lip of the pulley (not the part that holds the belt, the innermost part that fits over the rod part... you'll see what I'm talking about). Once it's on, you just tighten the bolt, which then pushes forward into the rod part, thus pulling the pulley off of the rod.
