Alternator Pulley Question
Old 07-02-2006, 11:00 AM
BoneSS's Avatar
Default Alternator Pulley Question
How do you get the pulley off? I have an Irragi, and am changing the pulley. It looks like a screw that can be taken off with a torx wrench in the middle of a huge nut that is in the center of the pulley. I have tried gripping the pulley with a pipe wrench and then turning the nut and then the torx screw, but can break nothing free. Thanks.
Old 07-02-2006, 04:18 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Ttt...
Old 07-02-2006, 06:05 PM
BoneSS's Avatar
Is it a reverse threaded sort of deal?
Old 07-02-2006, 08:12 PM
motoxlifer's Avatar
I think you have to use a box end wrench on the nut while holding the torx with a torx bit on a ratchet. At least I think that's what I did. And I think it is reverse threads.
Old 07-03-2006, 04:47 AM
BoneSS's Avatar
Thanks! I'll give it a try.
