A4 Cars With Tranny Coolers & Fast Toys Ram Air, Got A Question.
Anyone ever installed a Fast Toys Ram Air on a car equipped with a Tranny Cooler?
I am wondering where you moved the tranny cooler to get room to install the ram air kit?
Thanks,
Bill
Thanks,
Bill
alot mount it "dope style".o some people may say that you're not getting enough air to the cooler this way, but in the 3 I've installed i've never heard or seen any problems with the cooler not cooling. temps are right in line with styles in front of the radiator.
Thanks,
Bill
No matter where you mount your cooler it will be of at least some help. However, the efficiency of the cooler will depend on the specific location you choose. Efficiency ratings are as follows:
I didn't try it but there might be enough room to put it between the radiator and A/C condensor. I can't recall if the space between them is greater than the thickness of the cooler. If so, this location might be a good choice.
- In front of radiator = 100% (per B&M specs document)
- Between radiator and A/C condenser = 75% (per B&M specs)
- Behind A/C condenser = 60% (per B&M specs)
- Any other location in the engine compartment w/ both sides exposed to the air = 20% (I can’t recall where I saw this number. It sounded reasonable but I can’t vouch for it.) B&M specs say not to do this. Maybe this is what was called "dope style."
- Flat mounted on a surface such as the firewall is < 1%. If #4 is called "dope style," then this must be "brain dead style."
The guy that is doing my install has decided to install it where the window washer bottle was. This should provide enough airflow. I have the factory cooler also inline. So, if the B&M works even 20%-30% along with the factory unit it should be okay. I have a tranny temp gauge so I can keep an eye on it.
I am having the Fast Toys Ram Air and the Thunder Racing Coil Relocation package installed. So, it should look nice when I get it back.
Thanks for everyones input!
Bill
Cut out the passenger side splash guard grill and mount it there. I have mine there and my transmission stays very cool with the cooler in that location. If you crawl under the car you will notice if it is in place of the splash guard your going to be getting as much air to it as putting it in front of the air damn,which you can't do because of the fast toys.
