Tb Help
Tb Help
Hey guys I put a ported TB on my car and now it seems to idle high for about 3 seconds or so after start up and if i hit the gas what could be the problem??? Also nothing is sticking could one of the sensors be bad??? if so which one do i check first or could tuning the car make the prob. disappear??? Thanks for any help
Well I noticed it after the car reached operating temp. it will idle at like 1400rpms for like 4-5 sec and then drop back to normal idle after hitting the gas any clue???
How long has it been on the car, and how long has it been doing this?
You might try disconnecting the PCM for ~30 minutes and then letting the car relearn its idle. You might also have a vacuum leak after putting it all back together.
