FAST inner Gaskets
Old 07-18-2006, 04:13 PM
lilbuddy1587's Avatar
Default FAST inner Gaskets
Can anyone tell me if FAST sells the gaskets that seal the inside of the manifold ? I took mine apart to port/clean up the casting flaws but I fucked up the gasket . Any help would be much appreciated!
Old 07-18-2006, 04:15 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
YEah, they even have their own part numbers I believe.
Old 07-18-2006, 04:16 PM
CompTA's Avatar
Yes, you can buy them separately.
Old 07-18-2006, 04:18 PM
And that would be ?
Edit- Found em, thanks guys
Edit 2- Wrong gaskets
Old 07-18-2006, 04:19 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
damnit...hang on. I knew you were gonna ask me.
edit *cool deal man*
Old 07-18-2006, 04:22 PM
Ok, after looking at those pics on there website those aren't the ones I need. I'm talking about the gasket seals the entire manifold assembly
Old 07-19-2006, 01:38 AM
bumpity bump
Old 07-19-2006, 01:40 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
If I was at the other job I would be able to open the comp book and figure it out for ya.
Old 07-19-2006, 11:51 AM
Flow Wizard
Tony Mamo @ AFR's Avatar
I'm quite sure you wont find a PN on the internal gaskets that seal the manifold. There not suppose to be service items like the eight O-ring gaskets around the exits or the 90 mm round front seal.
Your gonna have to call Comp and see if they are willing to help you out. I would imagine they would be friendly to your cause. (Couldn't you just silicone the areas where you broke or ripped the gasket material??).
Anyway, bottom line is the gaskets you need will not be found in anybody's catalog, that for sure. Go direct to the manufacturer and see if there willing to help...
Tony
Old 07-19-2006, 12:01 PM
SiL3NtXWS6's Avatar
Tony
I think the seal is just a bunch of gasket pieces siliconed together. I don't think it's a form-fitted gasket.
Old 07-19-2006, 12:26 PM
daryl2cb@yahoo.com's Avatar
rope seal, call comp for the part number.
Old 07-19-2006, 01:31 PM
DrkPhx's Avatar
I ordered mine through SDPC as a special order through Comp. Had them in no time. Just make sure to be patient when you install them.
Old 07-19-2006, 11:10 PM
Tony
Gotcha, thanks Tony!
Everyone else, thanks for your help!
