Who sells stainless steel 3 inch exhaust pipe that goes from the y-pipe to muffler. I just need the pipe because I have an STS Kit. From what i've seen everyone sells alluminized.
SLP's, GMMG, magnaflow (I think). I think the loudmouth is stainless? They are cheap.
The problem with the LM exhaust is that it won't bolt up to my turbo, if you look at the way the pipe is shaped over the axle its diffrent then stock because LM uses no muffler.
