tensioner replacement when upgade on crank pulley?
i now have everything i need to put on my powerbond pulley, but how important is it to replace the tensioner when i do it? i have the new belts and threaded rod and all that install junk. i have also been reading about the install and am curious if using a little silicone on the pulley is nessesary i think i remember reading about that somewhere. thanks for any advice you can give.
That's what she said...
Originally Posted by DSRCAM
when i start my car my tensioner pulley kinda shrikes do i need to replace it or will wd40 work?
cool. my tensioner isnt making any noises, i figured i would let it go until it showed signs of needing replacement.--------------------any insight on putting silicone on the pulley when installing it. i only read one place that they recomended it to promote a goos seal to the engine, any input on that one???
