knock sensors / harness
Old 07-19-2006, 10:33 PM
JustAnIlluzion's Avatar
Default knock sensors / harness
i have a code for the knock sensors so i changed them both out but the code is still there. i now have a new knock sensor harness to hopefully fix the problem but need to know if this will remedy it, i dont want to remove the intake again for nothing.
Old 07-20-2006, 01:52 PM
ttt...
Old 07-20-2006, 02:06 PM
thunderstruck's Avatar
have you tried resetting the pcm?
Old 07-20-2006, 02:26 PM
2001NBMZ28's Avatar
Knock sensor codes are different for front or rear. Sure you didn't pinch the harness/connector when putting in new ones? I'd look up the code at www.gearchatter.com for any possible diagnostic steps before removing the intake.
Old 07-20-2006, 05:22 PM
tried resetting the pcm but the SES comes back on
i am pretty sure i didnt pinch them.
thanks for the link il try it
