how loud?
Old 07-20-2006, 05:10 AM
badnuz's Avatar
Default how loud?
just got a set of pacesetters lt for my 99 f body and getting ready to order a 3" x pipe with some kind of bulllet mufflers and td at the rear axel. dont wanna be as loud as my other drag car
Old 07-20-2006, 06:21 AM
300bhp/ton's Avatar
Is this a Question or a Statement?
Old 07-20-2006, 06:31 AM
kaell's Avatar
I'm also doing Pacesetters LT's and ORY-pipe, and then Twister-muffler dumped before axel. Will it be loud?
Looking for a descent sound level, and then convert to TDs...
Old 07-20-2006, 07:01 AM
badnuz's Avatar
no just a question
Old 07-20-2006, 08:06 AM
chadtx01's Avatar
Yes to both. LT's dumped under the axle are gonna be loud, especially in the car.
Old 07-20-2006, 08:20 AM
Beasst8's Avatar
Yes, LOUD.
Old 07-20-2006, 10:49 AM
spazzyfry123's Avatar
Exactly what I have on my 99 SS. I went with the ceramic-coated Pacesetters, the Summit universal X-pipe, and the Dynomax Bullet Race Mufflers dumped before the axle. Inside the car, the idle isn't too loud, but it's pretty damn loud outside of the car. It drones just a little bit around 2K and everything above 4K sounds like the C5R taking hot-laps at Road Atlanta. Once I get my cam in, I'm expecting it to be a Hell of a lot louder.
Old 07-20-2006, 11:27 AM
RICEETER's Avatar
yes indeed, my friend, you're wishes WILL come true.
Old 07-20-2006, 11:28 AM
Yes, I am thinking MS3 of all things too
Old 07-20-2006, 12:59 PM
300bhp/ton's Avatar
no just a question
ok, I'm guessing the question is "will it be loud with this setup?"
The answer is probably, but it depends on a lot. What other mods do you have? Are you running cats? Are you running the pipes out the back or dumping? And what sort of bullet mufflers are you going to run (core diameter, body diameter, length & make).
All of these will make a BIG difference and it could go from mild to wild.
Old 07-20-2006, 04:29 PM
blkZ28spt's Avatar
Longtubes, dumped duals with dynomax bullets and an MS3 is loud, but it's not race car loud (well, not as loud as a real race car). I daily drive that setup and love it.
Old 07-20-2006, 04:31 PM
BK1069's Avatar
i have the tsp rumbler w lts and it IS loud. i also have dynomat in my entire car and cabin noise is still there but if you turn the music up it does not bother you. you will also set of car alarms everywhere you go. it sounds very good, it had a deep tone
Old 07-20-2006, 06:50 PM
BuBbABFP's Avatar
DUUUDE! its freakin LOUD!
Old 07-20-2006, 06:59 PM
rayce08's Avatar
would adding cats quiet it ? i have wondered this .
Old 07-20-2006, 10:50 PM
donkey mule's Avatar
"Loud" is a subjective term, compared to stock it would be very loud especially at WOT.
Old 07-20-2006, 11:53 PM
blkZ28spt's Avatar
To put it in perspective a little...
I am a member of the Purdue Automotive Performance Association and most times people get together my car is the loudest and, IMO, sounds the best as well.
Stock engine with open longtubes seemed a bit louder, though it wasn't a back to back comparison so I could be wrong.
Old 07-21-2006, 04:57 AM
badnuz's Avatar
any other options on quieting it down but still runnnig true duals?
Old 07-21-2006, 10:38 AM
Adding cats will quiet it down some. It's still going to be loud, though. Also, running the pipes out the back of the car instead of dumping them before the axle will make it a little "less-loud". That way the sound vibrations won't be "bouncing" up and down under your ***.
Old 07-21-2006, 11:53 AM
300bhp/ton's Avatar
There are loads of ways of making it quiet. Stock Corvettes, Mustangs, Jaguars, BMWs, Mercedes all run duals and are all quiet.
It's all about the mufflers and design of the exhaust system.
Old 07-21-2006, 12:04 PM
carado1984's Avatar
no, get an MS4, and then send me a sound clip lol
