LS6 or FAST 90 for H/C 5.3
Old 07-20-2006, 08:16 PM
tdrumm's Avatar
Default LS6 or FAST 90 for H/C 5.3
I'll be ditching the truck intake manifold for some type of car based intake on my H/C 5.3. I've narrowed it down to either the LS6 (maybe a ported one by New Era) or a FAST 90 with LS2 TB. The heads flow a little better than stock 243s and the cam will be 218/218, .605/.564, 110. 3000 rpm stall converter with 4.10 gears.
Which intake would suit my combo better? Loss of low end is a concern to me as it is a fullsize truck and sees 95% street duty.
Thanks
Old 07-20-2006, 10:03 PM
black_knight's Avatar
Ported LSX 90mm. Tony M and EDC both port 90mm LSX's and show great gains across the range.
Old 07-20-2006, 10:49 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
FAST claims that there is not a lot of low end lost. I would go that route if mons\ey is not the issue.
Old 07-20-2006, 11:42 PM
On H/C there won't be a lot of loss, if there is even any. With a ported 90mm, you will probably gain low end.
Old 07-21-2006, 05:45 AM
tdrumm's Avatar
So you don't think there will be any losses down low? A couple of people have told me that the 90mm would be overkill. Even though this is a H/C it's a lot milder setup than an f-body on a smaller displacement engine and needs to move 1000 more pounds.
How much hp and torque could this be worth?
Old 07-21-2006, 06:16 AM
I know the following:
LSX90mm has shown losses down low on cam-only setups.
I haven't seen any H/C cars that have shown losses down low from LSX90.
Ported Fast90's have shown greater gains, especially under the curve for H/C cars.
All of the above applies to 5.7L. You have 5.3 (which I just notced. Oops!), so that's a wild card. I don't know how that will change the outcome.
Maybe you should find someone who ports these intakes and get their advice.
Old 07-24-2006, 06:07 AM
tdrumm's Avatar
Yeah, less cubes, more weight. I'm going to give Tony M a shout. I know one thing for certain, the truck intake is a POS.
Old 07-24-2006, 11:59 AM
RoastEmSS's Avatar
go with the FAST 90, and what does rcsb mean?regular cab short bed?
Old 07-25-2006, 05:56 AM
tdrumm's Avatar
Yep, Regular Cab Short Bed.
Looks like FAST 90 is the winner. Gonna have to save alot more for this project now.
