hose or tape to fix ory rattle?
I dunno if you read any of my other posts but i got a rattle where the ory is hitting the body...should iuse header wrap to fix the problem or stick a piece of radiator hose in there?
need opinions asap its getting pretty annoying (not to complain).
thanks guys
thanks guys
i have this problem too. i've tried to bend the header/y pipe and that doesn't help. I guess you could put something in between the places that are rubbing. i would use the header rap b/c it gets pretty hot. let me know how that works out.
Originally Posted by chad2775
I used heater hose and put header wrap around it for the heat, its working great so far.....
sounds fail proof to me
I put hose under my cat after trying to have the exhaust shop move it down a bit to no avail. Hose works fine IMO I've also heard someone welded a spring between they're y and bottom of car
thanks guys
thanks guys
Header rap will soak up water and rust the pipes, plus header rap is a real fire hazard if it gets oil on it, and lets face most motors/gearboxes leak a bit of oil.
A rubber hose is not much safer in this respect.
Simple answer:
Buy poly motor AND tranny mounts along with the Mufflex Y pipe hanger. They are all available from Thunder Racing.
The poly mounts are a great mod regardless of exhaust setup and should be done on any performance orientated car.
so...wrap the actual hose itself with header wrap, and then tape it on the exhaust with more header wrap?
Originally Posted by 300bhp/ton
Neither as both are dangerous ideas.
Simple answer:
Simple answer:
I put a old valve spring between my y-pipe and floor. I used 2 hose clamps put together to hold the spring to the pipe and put a piece of heater hose between the floor and the spring. I didn't want to weld it. The hose clamps hold the spring to the y-pipe almost as good.
I did order the mufflex bumpstop hanger, but after waiting two weeks of it being on back order, I had to resort to something else. I used parts I had lying around.
It's not a good idea to put a piece of hose right on the exhaust as the exhaust just gets too hot. I saw someone do it on a 1995-1998 style chevy truck and it started on fire. No damage was done to the truck as luckily a fire extinguisher was nearby.
What about some of that thermo-tec heat barrier. I don't remember exactly what its called, but I believe its adhesive on one side and thick enough to wedge btwn the pipe and body.
I think depending on the location the exhaust does not get THAT hot, I have had pieces of heater hose shoved between the floorboard and y for months and haven't had any problems. It shows no sign of melting... I checked it.
What is the heat tolerance for a piece of heater hose ? because if I remember correctly my temp gun was reading around 260* F on the pipe where the hose is.
I do have poly motor mounts and the bump stop but neither worked for me. I would rather not have the hose there if the poly trans mount would work, but I dont want to sacrifice any added vibrations if its not going to work.
will a new torque arm fix this? because that could be the first step i take in doin my suspension.
Simple answer:
Simple answer:
nope has nothing to do with it.
I went to autozone and bought the 2 thickest pieces of radiator hose I could find cut them up and wrapped them around the pipe where it was hitting then I bought some stainless steel bandclamps to hold the rubber pieces on, it still vibrates at around 1600-1800 rpms but it is about 1,000,000,000,000,000,000,000,000 times better than it was, cheap fix to a BASTARD problem
sawzall wielding director
If you are going to use heater hose get the silicone heater hose, it is rated for high temps. I have used it to patch the air injection tube as it comes out of the side of the cat on 80`s cars. If it can stand being clamped to the cat and not melt, or even discolor then it should be just fine against exhaust pipe.
