98-99 vs 01-02 headers
Old 07-28-2006, 10:34 AM
bitterchaos's Avatar
Default 98-99 vs 01-02 headers
What's the difference between headers made for 98-99 camaros and those for 2000 and above? Can I use 01-02 slp headers with a 99 Z28?
Old 07-28-2006, 10:40 AM
jmm98LS1's Avatar
The only difference is the location of the emissions fittings (air & egr). If you plan on deleting the air/egr, you can use any 98-02 header on any 98-02 fbody, just block off the emissions fittings. If you plan on keeping the air/egr, you'll have to modify those hookups, but it's not hard at all. My buddy used my 98-99 mac headers on his 2000 TA and we just shortened/bent the EGR tube and added some more hose for the driver's side AIR tube.
Old 07-28-2006, 11:29 AM
YellowMonster87's Avatar
Delete that ****!!!!! cleans up he engine bay and sheds weight!!!!
Old 07-28-2006, 12:00 PM
I need to be able to pass emissions though - I can buy inspection stickers but for $108 a piece. What would I need to do in order to make a 01-02 or 00 headers fit my 99?
Old 07-28-2006, 01:11 PM
Roarin_8's Avatar
Don't get slp headers unless you don't care about ground clearance.
Old 07-28-2006, 03:08 PM
RrCoX22's Avatar
'00 headers are the same as '98~'99... thought i might just clear that up for ya
if you need to put '01~'02 headers on your '99 you will need to get rid of EGR on your car (you won't pass smog without it)
...there's a sticky up top calling your name for you to read it
