Quick Question about the TB.
I am a Machinist in the navy, and I have the ability to Port my own TB. But I was also wondering. If I was to bore it out about .050 to .100. If that is possible and just make another plate. To replace the one that will no longer be big enough to fit in the hole.
If I did that, or even can I do that. Along with Porting it out. Would that be feasable? Can it be done with out distroying the TB?
Please let me know. I would like to try it out. and see how it would work.
Thanks
Lane
Thanks
Lane
With alot of trial and error you might be able to get it to work being in the career field you are in.....
but just so you dont go threw several tbs ...i would leave the blade alone...minus making the edges sharper and doing the half shaft mod.
-Chris
-Chris
sounds interesting, if you have good machinery. i think it would be an easy task, just bore it out perfectly round, measure the bore , make the tb blad just slightly smaller then that diameter(just enough to fit without rubbing), put it in the tb without drilling the holes(as the shaft may not be totally centered , then mark your spots for your hole with it in there ) youd have a bigger tb.. lots of work though. i just wonder whats behind or how far you can cnc into the stocker before you go too far, or punch through somewhere.
Thats what I was wondering too. How much material I can remove with out screwing it up. I have all the equipment I need to do it. I was just wondering on how affective it would be to do it. And if it is even possible with a stock one, Material Thickness that is.
