Quicky Engine Removal Question...
I've started removing my engine today. I am using Handzel's book as a guide. It appears that he suggests removing the engine with the wiring harness attached. I however feel that it would be easier and faster to unplug the wiring harness from the engine before dropping it. Anyone care to shine some light on this subject? That's all, thanks!
Thanks for the info. I've already started unplugging all of the wires from the block. I've gotten most on the bottom except for the exciter wire on the alternator, then I need to get the coil and injectors wires off too and I think thats it. I also have to remove the one clip from the back of the passenger side head and the one from the transmission. Any else to worry about?
Newcastle is about an 1:45 north of you, a little past Sacramento.
easier to removed the exciter on the alt if you loose the lil bracket on the alt and remove the bolt on the block to swing it over the make getting the clip up to pull the harness
its pretty self explained when the wires come off plus they only plug into one place when putting back together. you going from the top or bottom. i did mine all from the top. here at home
