question about heads
i am about to acquire a set of heads and wondering if i have to pull the motor to pull/put the heads on my 2000 z28....
http://www.ls1howto.com/index.php?article=3
follow these and you should be good... I would suggest you read them a couple times before you even get started and then follow along closely as you do it. Just take your time and make sure you have everything you need before you get started.
Good luck!
Good luck!
