low end power problem
Old 08-22-2006, 06:00 PM
zech86's Avatar
Default low end power problem
i installed a set of pacesetter long tubes, a k&n fipk and, and a hypertech programmer and i gained 1 mile per hour and lost a tenth. it doesn't start to really pull until about 3500 rpm do i just need gears or do u think i have a problem
Old 08-22-2006, 06:09 PM
LastHawk02's Avatar
is your car auto or stick, you probally did loost a lil low end with the headers cause of the backpressure
Old 08-22-2006, 06:19 PM
zech86's Avatar
it a 2000 z28 auto
Old 08-22-2006, 07:45 PM
jpat1023's Avatar
what is behind the pacesetters? stock crap?
You should have gained a little more...
Old 08-22-2006, 08:07 PM
cws T/A's Avatar
leave the gears alone for now
3500rpm + stall converter for your next modification
Old 08-22-2006, 09:34 PM
sixvi6-camaro's Avatar
Get a real tune.. HPP's are junk. Had a buddy that gained .1 in the 1/4 with dynatech headers and and an HPP. Then he got smart and had a basic tune done at speed inc and and knocked off .3. the difference was night and day.
Old 08-22-2006, 10:05 PM
zech86's Avatar
it has 2.5" x pipe and duals with 1 chamber flows full length
Old 08-23-2006, 01:02 AM
The PAT WS6's Avatar
get true duals or a good catback!
Old 08-23-2006, 07:44 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Ditch the tuner.
Get LS1-edit or HP Tuners/EFI Live.
Match up your stall speed correctly.
NEcessary bolt ons and good tune will go a long way.
Old 08-23-2006, 09:50 AM
TORCHD 02 TA's Avatar
i was wonderign the same with headers if i am going to lose some low end.. I have TD, with an x pipe and i knwo i lost a little low end. i drove my buddies 02 z with Kooks LTs + O/R H + 1 chmaber flows and his car was beefy under the curve.. Remember i am on stock manifolds for now until i get my QTPs in.. so will i gain some low end back with the LTs??
