Best Intake for all motor car??
Race your car!
all depends.. are you going all out with solid roller and 14-1 compression? If you are then I'd think a sheet metal would probably be your best bet for max power, or at least one of the single plane intakes port matched to the heads.
If it's staying a hydraulic cammed motor under 13 to 1 compression, then a sheet metal isn't needed.. fast 90 would probably be o.k.
