CME with a bullit muffler
has anyone done it? im putting on headers soon and want to re-use one of my bullit mufflers from my true duals set up. and can an exhaust shop do it like that? run the exhaust over the axle and then split it to run to the two sides of the tip?
yeah, put the bullit in the I pipe, then run the exhaust like it normally would over the rear axle, then split it and have it wrap around to the center mount tips. im just not sure if a normal exhaust shop can split the pipe like that.
I had my exhaust installed this past Wednesday and the shop I took it to was going to do it but my tips needed to be welded by the center bar and reinforced by another bar that connects them. They couldn't do aluminum welding and I had a hard time finding someone local to weld them up. I'll be taking my tips back to them once I can get them welded together.
But if your tips are good, they shouldn't have a hard time doing something like that.
