Header gasket blew!
Old 09-04-2006, 01:05 AM
ls1nightrider's Avatar
Default Header gasket blew!
Yep, I started up my car earlier today and noticed a loud fluttering noise. Checked it out and the driver side header gasket was blown . I have never changed one before but was thinking I could do this myself sometime tomorrow if i can find the gasket. What all do i need to take off in order to change it, any tips? Any help at all would be greatly appreciated because I would rather avoid paying someone 300 dollars to replace a 5 dollar gasket. Thanx in advance
Old 09-04-2006, 02:07 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Pull the spark plug wires and get in there with a small hand and stubby ratchet or boxed end. Get the stock style.
Old 09-04-2006, 02:08 AM
Grimes's Avatar
i'd bet that you could just take out all the header bolts, bend the header back a little, and slip a new one in there.
oh, btw, do yourself a favor and get some ratchting wrenches.
Old 09-04-2006, 02:47 AM
RrCoX22's Avatar
is it the passenger side? ...if so make sure you take those damn coil packs off
otherwise, ya plug wires, air and/or egr bolts, and headers bolts and your there
Old 09-19-2006, 01:07 PM
gnbooster87's Avatar
what if you have aftermarket headers, like pacesetters long tubes? i just blew mine this weekend. same side
Old 09-19-2006, 06:06 PM
ttt...
Old 09-19-2006, 06:16 PM
melchoir's Avatar
Driver side is easy, pull the wires, remove the bolts, the header will be supported by the Y-Pipe enough to allow you to just pull it back enough to slide the gasket in place.
Old 09-19-2006, 08:02 PM
yeah thats the easy part i want to know what brand of gasket i could use, and were i can buy it.
Old 09-19-2006, 08:05 PM
HeapaShifter's Avatar
Get a new GM gasket.
Old 09-19-2006, 11:27 PM
well anyone with pacesetters would see that the gasket that they provide is much thicker than the one GM offers,does it matter
Old 09-19-2006, 11:34 PM
Ferocity02's Avatar
Pacesetter gaskets are pieces of ****. They are made of PAPER. And paper + hot metal = bad news. I know quite a few people who have had their Pacesetter gaskets burned through. Just takes time. GM did it right with the MLS header gaskets.
Old 09-20-2006, 12:08 AM
Coy
Coy's Avatar
Do it right and unbolt the header from the y-pipe. it will let it turn enough to be out of the way. It's a bitch to get it to fit the right way and line up the holes with the flange in the way. It took me about 30 minutes from start to finish.
btw, use the stock style (MLS) like they said.
Old 09-20-2006, 02:04 AM
cool thankx, i remember seing the paper gasket and thinking will this work, but it blew anyways.
