Help!! Just Did LS6 Heads/Intake, Car backfires and has very slow throttle response..
Old 09-04-2006, 09:18 AM
killerbeez's Avatar
Default Help!! Just Did LS6 Heads/Intake, Car backfires and has very slow throttle response..
Hey so like the topic says, we did an ls6 head and intake swap and its not right..... The driver side banks is a lot cooler than the passenger, and it almost seems like it's running lean, also backfiring and has a rough idle. Is this something a tune would normally do? Sounds like it's a plug/wire/coil issue not firing and causing it to run lean....
Old 09-04-2006, 09:25 AM
BrandonDrecksage's Avatar
if stuff is not firing...its not lean ebcasue nothing is firing. Also, cold=not firing. The leaner an engine goes..the hotter it gets too. Who did the swap? sounds liek something get messed up. was the cam taken out? or set off of normal timing?
Old 09-04-2006, 09:39 AM
killerbeez's Avatar
no the cam wasn't taken out, the timing wasn't changed, what could we be looking at here?
Old 09-04-2006, 09:53 AM
GR33N GoblinM6's Avatar
1.check spark plugs for hairline cracks, this disturbs how they fire.
2.Check for the spark plug boots to be all the way on,
3.check the spark plug gap..
4. check coil back connections.
Old 09-04-2006, 01:19 PM
killerbeez's Avatar
oh my gosh dude that's exactly what it seems like. it's a 98, it seems like it's not firing right, where can I find out how to fix this?
Old 09-11-2006, 09:14 PM
csmc711's Avatar
Uhm, yea, your welcome?? I wonder what happened to him? Huess it was a hit and run
Old 09-11-2006, 09:19 PM
taintedmeat's Avatar
Maybe someone tried starting his car while he was holding one of the wires and he had a stroke.
Old 09-11-2006, 10:11 PM
bjamick's Avatar
dang somebody did something wrong. but ya mis fire problem most likely and i hope they matched the cam to the crank with the 2 lil dots.
Old 02-23-2007, 02:35 AM
lm7
lm7's Avatar
Originally Posted by Talon WS6
Each coil pack has a 4 wire connector and 3 out of 4 wires are the same color the 2nd wire from the top is different on all 4 coils.
Cylinder #1 = Purple
Cylinder #3 = Lt Blue
Cylinder #5 = Dk Green
Cylinder #7 = Pink
Cylinder #2 = Pink
Cylinder #4 = Dk Green
Cylinder #6 = Lt Blue
Cylinder #8 = Purple
This is off of a 2000 TA but should still be the same layout
Check out this lay out to yours.
im doing a coil pack relocation right now putting them on the cowl (thunder kit) and i need to make i put the right coil to the corresponding plug and not cross the wires....and this is exactly what i need i hope it works when i get off work tomorrow ill check it out. my coil packs have a yellow tag that say #1 of 8 on 1 coil pack on each side...whats the significance? at first i got excited and figured this must be cylinder 1 in the firing order but then i checked the passenger side and it had the same yellow #1 of 8 tag on one of the coil pack wires.
Old 02-23-2007, 08:19 AM
Taco's Avatar
That is, ummm, strange there...
Isn't the firing order 1-8-7-2-6-5-4-3? That may be useful info.
Also sounds like it may have a small vacuum leak. My car did this after swapping intakes and it was a loose intake bolt. Just something pretty simple to rule out.
Good luck.
Quick Reply: Help!! Just Did LS6 Heads/Intake, Car backfires and has very slow throttle response..
