filter removal tips? Need TQ!
Old 09-07-2006, 05:07 PM
ezrollin's Avatar
Default filter removal tips? Need TQ!
anyone got any tips on how to remove an over-tightened
oil filter? I usually just stick a screwdriver through it and it
comes off, but this one just shredded.
Old 09-07-2006, 05:15 PM
ezrollin's Avatar
there is like only a 1/4 of an inch (or less) screwed in, everything else just ripped off
Old 09-07-2006, 06:28 PM
Z28Venom's Avatar
Holy crap... you need to invest in a filter remover. You could trying getting a big set of vice grips around what's left. Who installed that filter?
Old 09-07-2006, 09:57 PM
67Ranger's Avatar
yeah, they make some straps that you can wrap around there, and use a ratchet to take it off. They work great.
Old 09-08-2006, 08:34 AM
Mr Incredible's Avatar
If your filter is already shredded you should be able to see the six or so holes on the steel plate. Put a screwdriver to one of those holes and tap it with a hammer to back it off.
I did that to one on my truck a long time ago. When it finally cut loose it spun like crazy all the way off and konked me in the noggin.
A good filter wrench is a must-have. I don't tighten them as much as I used to, only as much as I can do by hand, but not less than one complete turn after the rubber gasket touches. I may use a wrench to complete the full turn.
I use latex gloves when I change oil and they really give a good grip on the filter.
Old 09-08-2006, 09:26 AM
TAQuickness's Avatar
I went thru this on a Dodge Magnum. I eventually got to the point I could see the holes, then sacrificed a 24mm socket and welded 4 steel rods on it (same spacing as the filter holes). Hope it's my last 8 hour oil/filter change.
Old 09-08-2006, 10:41 AM
jmm98LS1's Avatar
......and this is why I use K&N oil filters, the nut welded onto the bottom makes life soooooo much easier.
Old 09-08-2006, 11:18 AM
bjamick's Avatar
most of the time when you spent the extra dollar it make life so much easier..
Old 09-08-2006, 11:45 AM
2001whiteSS6spd's Avatar
This is what you want it will remove any stubbern oil filter.
http://cgi.ebay.com/ebaymotors/OIL-F...QQcmdZViewItem
Old 09-08-2006, 03:45 PM
joecar's Avatar
Ditto on the pliers. Also available from AutoZone.
