Coil pack wiring Q
Coil pack wiring Q
How do I tell which of the plugs is for example for cylinder 1? There are no markings on the wiring and I was not able to find any wiring diagram with colors / codes.
I am doing a carbed LM7 and have bought the coil pack wiring (2 wires with one big plug and 4 small ones) new from GM.
Help me out, thanks!
TTT i have the same question, im relocating my coil packs how do i tell which is #1 and #7 i have them mounted in the new brackets. i guess if one way doesnt work there is only 1 other option ( back wards ) but, is there a better way to determine the which coil pack goes to which plug? markings on harnes? or pins on connector?
Originally Posted by Talon WS6
Each coil pack has a 4 wire connector and 3 out of 4 wires are the same color the 2nd wire from the top is different on all 4 coils.
Cylinder #1 = Purple
Cylinder #3 = Lt Blue
Cylinder #5 = Dk Green
Cylinder #7 = Pink
Cylinder #2 = Pink
Cylinder #4 = Dk Green
Cylinder #6 = Lt Blue
Cylinder #8 = Purple
This is off of a 2000 TA but should still be the same layout
Check out this lay out to yours.
Cylinder #7 = Pink
Cylinder #2 = Pink
Originally Posted by lm7
this is what worked for me.
I've relocated my coils and now run billit valve covers. I marked each connector with marker from the cylinder it came from, but this thread may come in handy one day.
