408 w/ GMPP Intake/Accel TB & Aerospace Vac Pump Setup PICS INSIDE!!!
Old 09-11-2006, 08:49 PM
1QuickT-A's Avatar
Default 408 w/ GMPP Intake/Accel TB & Aerospace Vac Pump Setup PICS INSIDE!!!
I know alot of people are always wanting to see pics of this setup so here they are. I had alot of trouble finding pics of Vac. Pump setups so here those are as well. The bracket was purchased from Tim Tosto and worked flawlessly. It bolts up where the a/c bracket once was. You can see the "custom" Aerospace BBC Mandrel drive in the pics as well..
Iron Block 408 with GMPP Intake & 1500cfm Accel Billet Throttle Body!
Aerospace Vacuum Pump & Tosto Racing Bracket
Close Up of the Tosto Racing Bracket
Old 09-11-2006, 08:54 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Nice--what do you figure for hp/torque???
Old 09-11-2006, 09:48 PM
1QuickT-A's Avatar
I'm not really sure what to expect.. I have seen so many different results from 408s that it is hard to tell. I'm sure it will easily have 550-600hp at the crank. Probably won't do that well on the dyno due to the big stall, th400 trans, steel shaft and 9in w/ slicks.
Old 09-12-2006, 08:02 PM
HeapaShifter's Avatar
It looks really good.
I'm jealous.
Old 09-12-2006, 10:01 PM
1QuickT-A's Avatar
Thanks man! If you want it bad enough you can have the setup you want as well!!
Old 09-13-2006, 12:07 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Should be a farkin tq monster!
