header bolts not going in right?
i noticed wehn i put my hooker L/t's in there was about 1 or 2 bolts on each side that didnt wanna go in nicely wats the deal with this? i am using fel pro gaskets ?
any help here ?
any help here ?
Originally Posted by orangeapeel
You need a cam..... that is what it is.
any help here ?
any help here ?
Im having the same god damn problem right now the rear and third from rear on the passenger side. I'm using stock gaskets
It kept me from finishing today....
Any luck getting around this???
I had my girlfriend threading bolts while i was holding the headers up and she cross threaded one of my bolts. What i did was wrong but worked so far, i carefully threaded the bolt in as far as i could get it without stripping or breaking (i mean verry carefully) i was able to get it abut 3/4 way in. I backed it out carefully and just shimmed it with some washers and carefully screwed it back in. (extra carefull at the end so i would not strip it out) This is not what you probably want to do but mine was fucked up and i will be getting new heads in a month or so anyway. I have no leaks and seems to be just fine. But i would not recomend this, maybe use a tap and carefully tap it out using oil that should help the bolt thread better.
any help here ?
any help here ?
Yep, clean holes with a thread chaser (or a tap, but watch out, a tap cuts metal),
lubing with oil as you chase, and back out and clean chaser often;
try to get to bottom of hole, but DO NOT FORCE chaser.
blow out with brake cleen and compressed air when done chasing;
clean threads on bolts with matching die chaser.
where can i get this tap or chaser stuff?
will the headers be able to move if the y pipe is connected?
thanks
oh and orange appeal i seen that in ur sig u said to fast for jordan and i see you live around here so i firgured u knew jordan mosley he drives a pewter ss and a r1.
thanks
did you put all of them in by hand or did you tighten a couple and then try to finish putting the rest in? you can get a tap at at just about any auto store or even some hardware stores.
tightend wat i could with my hands then the rest i left up to the wrench and there was one on each side that just didnt wanna go in right.
thanks
thanks
I had the same problem with my header bolts not wanting to thread in. They came out easy but when I went to thread them back in by hand, four of them were being stubborn. I went everywhere looking for a thread chaser but everyone gave me the "deer in the headlights" look when I queried them about it. I ended up just buying a M8x1.25 tap at the hardware store for $3.50. I CAREFULLY threaded it in by hand part way to make sure it was starting into the hole STRAIGHT. After I met resistance, I used a little wrench from an ignition wrench set (they're really tiny wrenches) to turn the tap. Each hole took about 3 turns of the tap to clean up the threads to where the header bolt would go in without hanging up. After using the tap, I used a q-tip to clean any metal shavings out of the holes. A thread chaser definitely would've been better for this but a tap worked just fine for me.
The last set I did was like that. Every hole in the header flange has got to be dead perfect and you have to hold your mouth just right.
Why not just try stepping up 1 size and running a drill bit through the holes to give you a few thousandths of clearance. It works.
Also I take the front and back bolt and get it started in the head with the header on. Then I take the stock mls gaskets and use a pair of tin snips to cut a slot in them so the gasket can drop in. Then go to the inner bolts.
