What am i missing in my engine bay?
When facing the cars front end, hood open, i have two screw holes on top of the passenger side wheel hump....what am i missing there? Its on the very edge, near the fender. I have seen pics and something is there, but my car does not have it...(2nd owner)
Also
i have one cable on my TB but there is a "nub" and an empty slot in the cable bracket,,,i have both traction control and cruise control, and both work fine as far as i can tell,,,,what goes on this "nub"? Thanx everyone
Also
you should only have 1 cable running to the TB if you have TCS and cruise.
And are you talking about the bolts that hold your strut and springs in ontop of the wheel well in the engine bay?
Good morning everyoiine, thanx for all the help. Im an idiot with the pic thing so i cant do that,,,(i tried as u can seee in my sig, but nada) but i do have a switch next to my lighter, really dont know if it does anything, cause i hit it, and nothing really happens, (lights, etc) Sometimes, usually during wheel hop, my TCS light will show on the dash, so i always thought that i did have it. Some of you mentioned that the recessed area of my fender hump is where it would be, and this is exactlly where i show nothing but 2 holes. Someone up here also said to pm them,,i will right after this post
thanx to you all....yep,,that lil box thing that is to the left of the firehawk logo on the wheel hump in the big pic above is where i have the two holes, and no box. I do have th eswitch, and on my original widow sticker, it states that i do have it. I am the second owner (originaly the Nasty Performance track car),,Nate must have removed the box,,does anybody know why someone would want to remove it? My car was modded much more than when i bought it ( things were removed and put back to stock, or as close to it as possible, i.e. corvette cam, etc.)
warp 10 - i have that same rub spot on my lid.
Yep. I have a WS6 lower box which has a bigger opening. That is why it's rubbing.
If you have a different rear end, they might have removed the TCS.
Cruise control works perfectly,,i use it all the time.
Dan
