Why is my car so quite and weak?
Old 09-15-2006, 10:30 PM
408Maro's Avatar
Default Why is my car so quite and weak?
hey guys whats going on i got a 02z28 with about 71k miles on her and i put on long tubes with a x pipe with dumped bullets and not i always read about how loud peoples cars are and past 3 grand its really loud but mines not really that loud and also when i gun it it bogs alot at wot in almost every gear(MN6 )whys is that any thoughts guys thanks guys always apreciate it. by the way i also get a check engine light every once in a while and it always says it has something to do with a 02 sensor
Old 09-15-2006, 10:40 PM
Formula_X's Avatar
This is unusuall, because I have the same system and its the loudest I've ever heard. Maybe you have a spark plug thats not firing and your running on 7 cylinders. Does the acceleration feel considerably slower than it used to?
Old 09-15-2006, 10:42 PM
408Maro's Avatar
not all the time but most times id say 90% of the time
67SS&99SS's Avatar
Check to make sure that your o2 extensions aren't burned. If your computer isn't reading the o2s, then that would cause it to run like crap.
Old 09-15-2006, 11:12 PM
408Maro's Avatar
thats crazy i just checked those yesterday and they were ok but just to make sure ill give them a closer inspection tomorrow thanks so far guys i apreciate it
Old 09-16-2006, 02:33 AM
GTO_Scott's Avatar
Do you still have cats and if so, are they plugged?
Old 09-16-2006, 06:39 AM
BrandonDrecksage's Avatar
did you get it tuned? headers tend to make you run rich..would do what your saying. The loudness part...sound is SUBJECTIVE. People say my rumbler is loud..I think its quiet.
Old 09-16-2006, 07:51 AM
shouldaboughttheZ's Avatar
car ever had a tune up?
plugs, wires, fuel filter, and tb cleaned.
Old 09-16-2006, 08:06 AM
Beasst8's Avatar
Yeah, I agree with this. When I put my cutout in, I cranked it up and was like....UUUMMMMM. That not nearly as loud as I was expecting. When you dont hear much in person you get this thought in your head about what you expect it to sound like. Then when you hear it in person, its normally quieter. Just my .02
Old 09-16-2006, 09:00 AM
408Maro's Avatar
hey guys thanks for your input so far i dont have any cats and no i havent had the car tuned yet and i did plugsand wires in like march. i dunno whats going on thanks so far guys i really appreciate it
Old 09-16-2006, 10:13 AM
RrCoX22's Avatar
make sure all your plugs and wire are good....
you may have burnt out an O2 as well
Old 09-16-2006, 11:26 AM
TORCHD 02 TA's Avatar
what mufflers are you running???
Old 09-16-2006, 11:42 AM
Jroc99SS's Avatar
If an o2 sensor is burned up wouldnt you be getting codes?
Old 09-16-2006, 12:00 PM
stangkiller's Avatar
i dont think not getting it tuned is the problem. i know of many cars that run fine without it (including mine). check all your plugs and wires #8 is always the toughest. then go to advanced or wherever and get it scanned for free. that should steer you in the right direction.
Old 09-16-2006, 01:53 PM
carado1984's Avatar
if youre not tuned you could be running really rich.. if your o2s are dirty you can clean them off with a torch..
Old 09-16-2006, 06:06 PM
408Maro's Avatar
ima check all the plugs and wires in the morning and im running dynomax bullets
Old 09-16-2006, 06:09 PM
00'WS6Rocket's Avatar
have someone rev your car up to 3,000 rpm whilst you stand outside of car
Old 09-16-2006, 07:14 PM
bjamick's Avatar
my thought is one of the wires isnt on all the way i would just take all them off then check the plugs to make sure there not black with oil, then make sure the plugs are tight, then put the wires back on and make sure you put some muscle behind it also sometimes you think there on and there really not. and make sure threre connected to the coil packs also.. hope this fixes it good luck man.
Old 09-16-2006, 10:56 PM
Formula_X's Avatar
I had my car tuned when I got the exhaust installed, you should have it tuned maybe. And defintely check the ignition like everyone's saying. It might be a bad plug wire or something as little as that. Good luck to you!
Old 09-16-2006, 11:08 PM
408Maro's Avatar
thanks to everyone for the help
