Vibtration at 2400 RPMs
ok my passanger side LTs were hitting the k member. and it was banging really bad and vibrating horribly.. So i nothcehd out the k meber where the LTs were hitting. so viola no more banging.. But at 2400 RPMs any gear 1st - 5th it vibrates but no where near what it was jsut bothers me a bit. At that speed of the motor is that were the LTs have a tone to just vinbrate??? I do not think that poly motor mounts will fix this. any one else have any idea???????
That's what she said...
That's resonation, learn to live with it. My TSP duals did it at 2100 when I was dumped, and I had the mounts. Anything you connect to the system or change will change it's "natural frequency" which is where the resonation is happening.
Poly motor mounts might help, and should clear your banging too. After all the 6000 posts of mine where I recommend them, why in the hell didn't you buy a set?
I've only read about 4,563 posts.. i'll call your bluff.
yea i kind of figured that at that frquency it was making it vibrate.. was jsut curious.. thanks casey! i ahve no more banging! What exactly will the poly motor mounts do? they have no give to them.. it will like a race car then??
