l98 tpi 350 s10 swap
im in the progress of installing an l98 tuned port trans am motor in my s10, does anyone know if there is a wiring harness adapter or somthing for the fuse block or do i have to take the fuse block and all the wires out of the dash and swap fuse block. what im saying is i pulled this motor with every harness and unbolted the wires from the fuse block on the firewall and the computer and some reason i thought that the fuse block wires would mount right up but, there not at all the same. ive done a similiar swap before with a nova but it was gutted for racing (wasnt hard to swap interior wires then) and i swapped the fuse block as an upgrade from them glass fuses worked great. any help would be appreciated
you need this moved to the conversions thread..
and this is an LS1, LS2, LS6 LS7 board...
try www.thirdgen.org
there are multiple threads over there on putting a TPI engine into other cars.
