remove a stubborn Crank bolt to change pulleys
car: 2001 z28 m6
mod: swapping stock crank pulley for an underdrive SLP pulley
issue: cant break free the factory crank pulley.
Tried attempts:
1. Mac pro impact gun - crank bolt didnt break free
2. one person holding a strap wrench around the pulley, another using a breaker bar on the bolt. - crank bolt still didnt break free.
3. (clutch was removed) one person holding a strap wrench around the pulley, another using a pry bar between two bolts on the flywheel, and the other using a breaker bar (with a pipe over the bar) - bar still didnt break free.
Now all three of us are strong guys but damn the bolt will not buldge.
Does anyone have any tricks/ideas that we havent tried. Currently we soaked the bolt with Penetrating Blaster and hope that will help break it free.
We where suprised the impact gun did not zip it off.
Tried attempts:
i tried my little half inch inpact gun, the bolt laughed at it, so then i got the 3/4 inch impact gun bolt still was laughing, but it eventually came off, but it did right before i was about to try it with the 1" behemouth.
I used a propane torch and just heated the bolt up for a solid 5 minutes. Once it cooled enough with a little elbow grease it popped off.
I have heard of people using a breaker bar, setting it against the ground and tapping the starter a couple times but it never sounded like a good idea to me so i wouldnt recommend it.
I just got mine off with a 27in breaker bar. Came off allot easier than I thought. THEN, the ARP bolt got stuck in the crank. That took a machine shop with a HUGE impact and lots of time to get out.
