weiand intake?
17,16,15,14,13,12,11 Drvr
weiand intake?
on the back where the map sensor goes is there a retainer clip that holds the map sensor in place? it just slides in and wants to fall right back out. Has anyone swaped to a weiand intake? thanks for all the help.
That's what she said...
FAST manifolds have the same problem. I recently found that you can buy a new rubber grommit that slips over the nipple on the MAP sensor. The old one is probably worn out.
It can have a bit of a loose fit as there is a vacuum holding it in 90% of the time.
This rubber piece is $4 from your local stealership.
