180 thermostat
Originally Posted by ZROCWS6
With a EFI car you want the higher temp for better fuel burn.
optimum coolant temp is 200 - 210 am I correct? I mean combustion chamber temps will always be way hotter, but the coolant temp too cold can interfere with that?
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Originally Posted by JEB Garner
Change the 180 thermostat for s 160 thermostat.I find that the cooler running engine runs better.
Originally Posted by orangeapeel
a 160° is gonna actually read around 175-185.
I don't think it's been proven that ls1s work better when hotter, in fact from what I have seen on a dyno the opposite is true: the cooler running the engine (relatively speaking) the more power it rolls on the dyno, but I don't think there is data either way which is better.
Moderator
My "160" cracks about 177F. My stocker was 194F.
The "180" is the real waste of money. Unless you
are forced induction or really high CR I say stick with
the stocker and just get the fans under control.
