Cleaning the K&N filter Q?
Old 10-03-2006, 05:05 PM
Moderator
davered00ss's Avatar
Default Cleaning the K&N filter Q?
I just bought another kit to clean my K&N filter. I have 2 bottles of the oil left & I seem to be using a lot of the cleaner. Can You just use Simple green on the filter to clean it? I have seen people use simple green on the filters for their prochargers. What is that cleaner anyway?
Old 10-03-2006, 05:13 PM
LS1>girlfriend's Avatar
i wouldnt use anything but the k&n cleaner, but i dont clean my k&n i go by a new one in fear of over oiling and they never come completely clean
simple green works good on brake dust, removeing oil and cleaning the garage floor.
Old 10-03-2006, 05:22 PM
Moderator
This is the 2nd K&N filter on the car. With the free ram air mod, the filter gets dirty quick.
Old 10-03-2006, 05:56 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Lightbulb
I use SUNLIGHT DISH SOAP to clean mine...outside with a hose...has been fine for years..Sunlight is easy on your hands, it can't very well harm tough fabric in the KN........[ RINSE THOUROUGHLY ]
Old 10-03-2006, 06:23 PM
Moderator
I was thinking Simple Green because it will remove the oil well. Also I have seen it used on other cone style filters before.
Old 10-03-2006, 06:38 PM
Ls1CamaroGuy87's Avatar
i just use dish washing soap, with no problems thus far. Although, I will be switching to Fram paper filter for obvious reasons..
Old 10-03-2006, 06:55 PM
NHRAMAN's Avatar
Question
OBVIOUS REASONS .............
Old 10-04-2006, 04:30 PM
Moderator
What obvious reasons?
Old 10-04-2006, 04:48 PM
NHRAMAN's Avatar
Question
I don't have a clue--I was making fun..
Old 10-04-2006, 06:17 PM
why would you make fun, how about you do some ******* research on those filters for our cars before you say ****.....go ahead use search and see what comes up.....lets see.....the oil that needs to be put on them ***** up the maf..could set off ses by doing that...also k & n filters do not filter as good as papers ones and they add no horsepower...the only real benefit is that they can be cleaned and last for a long time...do ur research
Old 10-04-2006, 06:20 PM
Moderator
Oil on the MAF---Don't over oil it
Filtering-- Never seen any proven info
No hp increase---leave it to the every little bit helps.
Old 10-04-2006, 06:28 PM
ok whatever you say, every little bit helps when it comes to the k&n filter is like telling a guy with no legs that they will grow back
Old 10-04-2006, 06:36 PM
LSGunZ28's Avatar
I dont believe the paper filter outflow the cotton Gauze filters. why dont you try on the flowbench before making obsurd comments.
Old 10-04-2006, 06:38 PM
obsurd comments? people have tested it out on a dyno, it shows no difference from paper ones, but you guys just believe whatever you want. I just think paper ones are better no more comments, thanks
Old 10-04-2006, 06:41 PM
ddelallata's Avatar
I've found that it is easier to prevent over-oiling the filter with the spray-on oil can from K&N. The one that you have to run through every pleat on the filter element can result in a very messy and damp oil filter if you are not careful. Go to the autoparts store and look for a Recharge kit that comes with the spray-on oil can.
Old 10-05-2006, 05:35 PM
Moderator
I just got the spray on oil kit. I think I like the old oil bottle better.
Old 10-06-2006, 07:16 AM
jam01's Avatar
the oil on the filter is what helps it trap more dirt than a paper filter. as far as flow characteristics i dont own a flow bench or tool to check, but it cant be any worse. as far as them screwing up mafs, just dont over oil them(light pink)i know all of mine came with instructions. as far as the cleaner they use call k&n and ask.
Old 10-06-2006, 10:02 AM
LS1Tech Sponsor
Slowhawk's Avatar
Soak it with simple green and wash off.
DO NOT OVER OIL THE FILTER!!!!! It will get all over the MAF and screw up the tuning!
I actually run no oil.
Old 10-06-2006, 10:14 AM
Wolfgang427's Avatar
I wouldn't use simply green to clean a K&N. Simple green is a tough degreaser and the oil K&N uses is a very light oil, unless the filter was over-oiled to begin with. If you have to use simple green the least you should do is dilute it.
KY Z28's Avatar
As another good tip, if you see that your K&N has all kinds of junk in it (especially common if you have the ram air mod), just use compressed air and blow it out. Be sure that you blow from the top side and not the bottom though. Some people say that this damages the filter blah blah blah but I have been doing it for years on both cars and quads and never once had a problem cleaning them like that.
