Jet hot y-pipe
Jet hot y-pipe
Just purchased jet hot long tube headers with an ory and i have two questions about the y pipe. 1- What type of clamp or u-bolt would you recommend to hold the y pipe together. 2- the y has 02 bungs welded in and im not using these so i was wondering what to use to plug these? Any ideas are greatly apprecated!
ЯєŧąяĐ Єl¡m¡иąŧøя ™
1. Band Clamps. They are about 4" wide and will securely fasten exhaust. I had them on my 4" Mufflex setup. Loved them. Better than crimping your pipes with a u-bolt.
2. Fill them in with weld bead, or get a bolt that matches the pattern and cut it to where it does not protrude into the pipe.
before you keep the jet hot y-pipe look inside and notice the tube overlap basically its hurting your horsepower return it and have a custom one built, unless jet hot will fix it for you
