Flush kit - which heater hose do I cut???
I want to flush my cooling system because I have no heat and my car runs hot during idle. I already replaced the waterpump, thermostat and performed a normal Prestone flush and I still have no heat and my engine gets up to 210 when stuck in traffic. I am thinking that I may have a clog in the system. Is it ok to use a flush kit that comes with a tee so that the system can be backflushed? If so which hose do I cut to install the tee that the garden hose attaches to? I looked at the instructions on the kit and it says to cut the heater hose runing from the firewall to the top of the engine and not the one that attaches to the waterpump. When I look at the two heater hoses they both attach to the waterpump. What gives???
THANKS
THANKS
check your radiator... get a hose or an air compressor and blow your radiator out. the little fins are probably clogged. if the fins are clogged you get no air flow through the radiator and it will make the car run hot. from my experience i have never had a coolant system flush help whatsoever with how hot the car was running. my Z used to run right around 220 at stop lights.. cleaned my radiator out and it has never gotten over 195 since.
