where can i just buy some bullets mufflers
I'm not sure what size i need so if someone knows please let me know... i want to have a true dual setup made but i want to put my own mufflers on it, i just don't know where to get them or which size would be best....
Location: Your girl's back door giving her the long stroke while you're at work
Check the sponsers first; it's always a good idea to support them. If they don't have what you are looking for contact the Jegs or Summit. Most TD set-ups are either 2.5 or 3 inches, so whatever size pipe you go with that is what size the inlet/outlet diameter needs to be
what you should do is go to a shop and get a quote for the labor..tell them the dimensions of the mufflers. Soemtimes its easier to jsut pick up the tsp rumbler and have them adapt that to your system. You figure for bullets you would pay 100-150, the clamps, pipes...ect. I don't think any sponsers sell just the mullfers alone though.
less ground clearance the longer the bullet...12" is the size of just the muffler itself, add 2" to each end for the exhaust pipe part of the muffler. so a 12" bullet is really 16". If i have time ill go measure mine to get exact length.
