warm ac after waterpump
Old 10-16-2006, 05:00 PM
crazymofo1986's Avatar
Default warm ac after waterpump
i replaced my water pump and now my ac is warm. i put the ac on hot high and to the feet to bleed the coolent. when i got it i changed it to cold. it wasnt hot nemore but warm. everything changes and i can make it hoter jus not cold. check under the hood and the canister was dry not cold and wet like normal. ne idea?
Old 10-16-2006, 10:10 PM
lomaximumta's Avatar
I fixed mine by changing the fuse? Check that...
Old 10-16-2006, 11:36 PM
taintedmeat's Avatar
Maybe you leaned on the tube that comes out of the evaporator and busted the o-ring in it. I did the same thing, ended up buying a new tube for 40 bucks from GM parts direct.
Old 10-17-2006, 12:00 AM
if i buster the o ring the charge ould have shot out right? where is the fuse i switched relays n it was fine
Old 10-18-2006, 08:32 AM
jam01's Avatar
try driving the car for a couple of miles. if it felt warm right after you were done replacing your pump, its probally just heat soak at the condenser.
Old 10-18-2006, 08:34 AM
O-ring was still in mine when I removed it. Only way I knew I had actually busted it, is I was charging the system back up, and refrigerant started shooting out of that fitting as I filled it. The whole can of r134 I had just paid for emptied out because of that.
Old 10-18-2006, 07:38 PM
well the 2 wires that go to the compresser one of them i guess snaged on sumthing and cut it. soildered it back together and it was cold again.
