ls1 vent tubes/ fast 90
anyone modify there ls1 steam vent tubes to work with a fast 90?
im in the process of it and wondering if anyone had any better idea's then what im doing.
also anyone run a mezeir ewp with the fast 90 ? my ls1 manifold had to be ground alittle to clear- i dont wanna touch my fast 90 with a dremel.. too$$$$.
What's the problem with the tubes and the intake? Cut? Bend? They're stainless, can do anything you want. Treat'm as miny exhaust pipes...
As far as the intake is concerned, it doesn't look like you have much of a choice if mod's are required. You spent the money for the intake AND the pump...if you want them to work together, grind away.... Look at this way: How much did you spend on your car before chopping into it? Probably a little more than $1000+ worth of parts, right?
